Home > Message Board > Car Audio > Speakers > Archive through April 04, 2006 > Need some help for choosing door spea...
Author Thread: Need some help for choosing door speakers
Username: Vladimer
alright, well im in need for some help cause im completly lost as to what kind of speakers to get, to many choices, to many price differences lol,
currently got a 12" infinity sub with a ultimate T3-2050 amp and a clarion HU, dont remember the model name, bass wise, im more then happy with
speakers... well.. after putting it near 20 on the volume control, the speakers start crackling and breaking up so im pretty dam sure there in need of upgrading,
looking to spend about 200-250 bucks, most bang for buck if possible, front speakers are 6 1/2 and rear are 6 x 9, and compontents, i have noooo clue, when i go to sounddomain.com they dont mention anything, and when i called futureshop and they looked on there computers they said no but i swear i hear audio comming out of the dash somewhere lol, i drive a '01 hyundai tiburon
thanks alot for any help cause im totaly lost :S
Username: Stephene
Lefroy, Ontario
Im not sure about that car but the sound coming from the dash are probably stock tweeters. I have a 92 Jetta and I didnt know mine had stock tweeters until i went to install mine. Anyways for speakers you can get good pioneer 3-way 6 X 9's for like $85. Thats what i have right now and they work perfectly, havent had a problem with them yet. You can also get some 6 1/2" for the front for about $80 as well.
Username: Vladimer
well i took a look around sounddomain since localy i got like crazy prices on everything =/
Pioneer TS-A6991R
http://www.cardomain.com/item/PIOTSA6991R?vq_id=none#reviews
Pioneer TS-A1681R
http://www.cardomain.com/item/PIOTSA1681R?vq_id=none#reviews
would these be a good choice for the money being spent? cause in total it only comes out to about 160 bucks
would these run fine off the stock power and wires or should i buy some smaller amp to power them and replace the wires
thanks again
Home > Message Board > Car Audio > Speakers > Archive through April 04, 2006 > Need some help for choosing door spea... [ « Previous ] [ Next » ]
