Thread: Viper 5000 range problem |
New member Username: Razvanro
Post Number: 1 Registered: Mar-06
| Posted on Thursday, March 16, 2006 - 11:02 am: |
can anywone know haw to boost the range of my viper 5000 because if I give a command my car will do but the pager doesn't receive back the signal for confirmation |
Bronze Member Username: Ruthless06
Post Number: 87 Registered: Feb-06
| Posted on Thursday, March 16, 2006 - 11:34 am: |
If you give the command, like to say, remote start, and it remote starts. But your 2 way system doesn't let you know. Then it could be a few things. Either the two-way transponder system has faulted out. The remote could be bad. One of the wire in your antenna could have shorted. Or maybe the brain isn't sending a signal. I would try to get a new remote and try that first. |
New member Username: Fadmaid
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 23, 2006 - 06:05 pm: |
i have a big problem! i have a viper alarm on a ford transit. and i think so because my remote says so. fcc id:ezsdei 474v; rpn 473v. sometimes my alarm deactivates silenly by ITSSEFL! and today insead of two beeps on the deactivation it gave my like 4 or 5. can i fix those problems? how do i eve fiind out my alarm series? thank you very much. |
New member Username: Justin27
Jackson,
NJ
| Posted on Thursday, July 27, 2006 - 08:37 am: |
i have a big problem i sent my remote through the wash so i can not deactivate my alarm i used to be able to bypass this now i cannot figure it out and i need to program a phython remote to it ....any suggestions? email me at Jtownkid17@hotmail.com ...thanks |
