Thread: New HD in 05 Chevy Impala |
Bronze Member Username: Xdream
Sherman oaks,
Ca
Post Number: 37 Registered: Oct-05
| Posted on Sunday, March 12, 2006 - 04:09 pm: |
hi i wanna change my head unit so that i can hear mp3 disks, the problem is that i have the cd decks gm and chryslers have... aNd they are the big ones that look twice the size of normal ones, basically the only ones that i found that are made for my type of car are pioneers DEH-P47DH. the thing is that they are like $400 AND dont look that good. is there any other brand that make cd players that im looking for, and have mp3? also should i just get a normal slim cd player and have all this extra space around it? also is there a special plastic plate to transform gm size radios to the small normal civic type radios? |
Gold Member Username: Tjmutlow
Post Number: 1631 Registered: Sep-05
| Posted on Monday, March 13, 2006 - 01:07 am: |
they make dash kits for this and you need a special harness for it, and other pieces if onstar or bose systems... |
Silver Member Username: Jeremyc
Germany
Post Number: 846 Registered: Jun-04
| Posted on Monday, March 13, 2006 - 02:52 pm: |
and you will need an antenna adapter. Look at crutchfield or CC. You can enter youir car and it will tell you what adapters to get |
