Thread: Need Help |
Bronze Member Username: Nypdlapd
Post Number: 45 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 07:08 pm: |
My brother rewired his headunit and the ground and constant 12 volt wire touched.. but the wireharness was not connected to the H/U.Now the H/U does not turn on. what do i do to make it turn on?? |
Post Number: 46 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 07:13 pm: |
do i need to rewire the ground?? or the constant.. |
Post Number: 47 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 07:18 pm: |
i no it is not the headunit.. |
Gold Member Username: Illuminator
Post Number: 2733 Registered: Apr-05
| Posted on Saturday, March 11, 2006 - 07:23 pm: |
Check the fuses before doing anything else. If they are all fine, you probably need to hook up the ignition wire as well to the head unit. |
Post Number: 48 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 07:25 pm: |
i did hook up all the wires How do i no if the fuses are dead?? |
Post Number: 2734 Registered: Apr-05
| Posted on Saturday, March 11, 2006 - 07:30 pm: |
Check every fuse on the main fuse panel, specifically the radio fuse. |
Post Number: 2735 Registered: Apr-05
| Posted on Saturday, March 11, 2006 - 07:32 pm: |
The metal piece between will be broken and/or they'll be blackened:
Post Number: 49 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 09:00 pm: |
all the fuses are good i think it is the ground wire because the Ground TOUCHED THE +12 VOLT |
Post Number: 53 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 09:24 pm: |
Is it the ground wire or +12?? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1341 Registered: Feb-05
| Posted on Saturday, March 11, 2006 - 09:38 pm: |
try running another ground or +12 and see. or use a meter to figure it out. no other way to tell. that should have just blew a fuse though. i have 2 fuse boxes in my car, one in the car and one under the hood. sure you don't have more someplace else?? |
Post Number: 55 Registered: Feb-06
| Posted on Saturday, March 11, 2006 - 10:12 pm: |
I have a 1990 chevy astro |
