Thread: Clarion HU |
Silver Member Username: Ucfsaxman
Oviedo/orlando,
Fl
Post Number: 674 Registered: May-05
| Posted on Thursday, March 09, 2006 - 01:13 pm: |
My mom's car(03 galant) has 2 pretty decent pioneer 10's they're a few years old but better then the current stuff out by pioneer. So a few months ago i got my mom a clarion deck it is a lower model one but clarion is still considered to be decent(right). There are 2 problems the first is that the bass is no where near what it once was w/ the stock mitsubishi HU. With the old stock HU the bass was really thick and loud it wasn't that clear but thats to be expected. So we switched out the HU's with the clarion deck and ever since then the bass from the subs is just barely there if at all. Also this new clarion deck cannot pick up half of the radio stations the older Hu did. So my question is, is the clarion deck worthless and should we just put the stock one back in or is something possibly not connected correctly w/ the clarion HU? |
Gold Member Username: Illuminator
Post Number: 2728 Registered: Apr-05
| Posted on Thursday, March 09, 2006 - 02:36 pm: |
The Clarion probably needs the subwoofer output volume turned up. As for the radio reception, it shouldn't be any different...are you talking AM or FM? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1268 Registered: Feb-05
| Posted on Thursday, March 09, 2006 - 02:39 pm: |
sounds like a gain isue on the amp pushing the subs. the LOC used with the factory unit (LOC right?) was prob putting out more power then the new HU's pre outs and you need to re adjust for that. might want to play with sub levels and EQ's on the HU too. |
Oviedo/orlando,
Fl
Post Number: 676 Registered: May-05
| Posted on Thursday, March 09, 2006 - 10:02 pm: |
yes i meant Fm and thats what i had though there shouldn't be a difference but for some reason it is worse. there aren't really any adjustments w/ this head unit its just simple bass and treble and then 3 settings that are supposed to maximize either treble, bass or a mixture of both. i turned up the bass to as high as it will go. I'm now beginning to believe that it is the amp although the amp was fine before the subs were plenty loud but now there is nothing. the amp recently has had probelems w/ the adjustment and the gain knob more or less broke before i had a chance to even adjust it. so i can't really do much w/ the amp. |
Post Number: 2729 Registered: Apr-05
| Posted on Friday, March 10, 2006 - 12:14 am: |
Looks like Brandon hit it on the head. |
Stockbridge,
GA
Post Number: 1291 Registered: Feb-05
| Posted on Friday, March 10, 2006 - 10:56 am: |
yay, i got somethng right, lol. i do that every once in a while. :P when i went from the Alpine CDA-9813 with 4V pre outs to the Panasonic DVD unit with 2V pre outs, i had that same deal. that adjustment makes a huge difference when set right, lol. but the knob is broke?? can you adjust it with some needle nose pliars or anything?? |
Oviedo/orlando,
Fl
Post Number: 682 Registered: May-05
| Posted on Friday, March 10, 2006 - 04:28 pm: |
no i've tried i took off the back metal plate of the amp and the gain is broken i have no way of telling what is higher or lower and when i try adjust it w/ the system on nothing happens. so would you say there isn't really anything wrong w/ the HU its more the amp. BTW thanks a lot for helping me on this guys i really appreciate it  |
Stockbridge,
GA
Post Number: 1302 Registered: Feb-05
| Posted on Friday, March 10, 2006 - 07:41 pm: |
i'd say look into another amp. the HU should be fine. no problem ucfsaxman, thats what this things for. hope you get it all working right. |
