Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Python 650ESP alarm
Author Thread: Python 650ESP alarm
Username: Wendyc
Hi, I recently bought a replacement remote for my car. The alarm installed is a Python 650ESP and the FCC ID on my remote is EZSDEI471. I was wondering if anyone can tell me how I can program it to work? Thanks! Please email me at femalecsi@yahoo.com
Username: Ruthless06
Post Number: 37
isnt python made by directed? i think so. if its like every other directed product ive installed do this...
turn your ignition key to the on position
hit your learn/valet switch one time
then hold this switch and hit the lock button on your new remote. your siren should chirp, or your horn whatever, and your indicator light will blink once. turn the key off and see if it works.
gl
Post Number: 43
hmm, didnt move up
Username: Wendyc
Hi, Thanks for the tip. I'll try it out! =)
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Python 650ESP alarm [ « Previous ] [ Next » ]
