Thread: Bridging headunit |
| Posted on Wednesday, March 01, 2006 - 12:55 pm: |
At the moment my head unit drives four speakers, 2 on my dash and 2 in my front doors. The ones in my dash are too close to my head and are very small so are pointless. Can i disconnect them and instead bridge the ouputs on the headunit, so i have more power going to the bigger ones in the doors? if this can be done i intend to buy better speakers for the doors. |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 1180 Registered: Feb-05
| Posted on Wednesday, March 01, 2006 - 01:02 pm: |
no, you cannot bridge a HU. but by disconnecting one set of speakers, i've found that the set still hooked up will receive more power and won't distort as soon as with 2 sets hooked up. but if you really want more power, you should look into an external amp. |
| Posted on Wednesday, March 01, 2006 - 01:06 pm: |
Thanks for that. i got an amp in boot and two 6x9's in mdf back shelf - they kick but front cant keep up and it doesnt sound good as soon as i go loud. im going to try disconnectin the two smaller speakers, my standard stocks in the doors arent too bad. |
Gold Member Username: Illuminator
Post Number: 2709 Registered: Apr-05
| Posted on Wednesday, March 01, 2006 - 02:57 pm: |
Have you tried the fader on the head unit? |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11289 Registered: Dec-03
| Posted on Wednesday, March 01, 2006 - 09:04 pm: |
head unit bridging: http://www.bcae1.com/brighead.htm
