Thread: Eclipse cd8445 or cd8455 |
New member Username: Pvduk
Post Number: 2 Registered: Feb-06
| Posted on Tuesday, February 28, 2006 - 09:07 pm: |
Can someone please point out the differences between the two and what final outcome that has on the SQ output??? The cd8445 is going for $280 brand new on eBay, and the cd8455 for $455 used!!!! I think the demand for the cd8455 makes it much less value for money!? Please anyone with experience and knowledge on this subject reply! thanks |
Post Number: 4 Registered: Feb-06
| Posted on Monday, March 06, 2006 - 06:27 pm: |
Bump! Please you guys, a simple answer will suffice! Jonathan or Glass!?!?!?! |
Bronze Member Username: Delsole
Post Number: 82 Registered: Feb-05
| Posted on Tuesday, March 07, 2006 - 04:30 pm: |
cd8445 its new and u will save alot of money |
Silver Member Username: Jeremyc
Germany
Post Number: 843 Registered: Jun-04
| Posted on Sunday, March 12, 2006 - 10:11 pm: |
Yeah unless you plan on running an active front stage go with the 8445. The 8455 is better, but not worth the extra $$ unless you plan on using it to its full potential. |
Silver Member Username: Delsole
Post Number: 119 Registered: Feb-05
| Posted on Monday, March 13, 2006 - 07:55 pm: |
true true |
Bronze Member Username: Ruthless06
Post Number: 74 Registered: Feb-06
| Posted on Tuesday, March 14, 2006 - 12:38 am: |
the 8445 has a 7 band eq. the 8455 has a 10 band eq the 8445 has no digital input the 8455 does the 8445 does not come with a mic the 8455 does the only differences between the two. |
Post Number: 150 Registered: Feb-05
| Posted on Tuesday, March 14, 2006 - 06:57 pm: |
jus get the new cheaper one staight up |
Silver Member Username: Lil_jon
Post Number: 349 Registered: Jul-05
| Posted on Wednesday, March 15, 2006 - 12:53 am: |
get the 55 when its time to upgrade your speakers to high end your gonna wanna go active you wont be able to do that with the 45 |
Silver Member Username: Vinnyqh
Portland,
OR
Post Number: 195 Registered: Nov-05
| Posted on Tuesday, March 28, 2006 - 03:26 pm: |
als othe 8445 doesn't even have the option for getting a mic. and the 55 has a better DSP inside, hence the 7 band and the 10 band. |
New member Username: Jchin2
Post Number: 1 Registered: Apr-06
| Posted on Friday, April 21, 2006 - 01:50 am: |
is the old model 8061 good? |
Silver Member Username: Extrmndor3
Chicago,
Ill
Us
Post Number: 554 Registered: Feb-06
| Posted on Wednesday, April 26, 2006 - 03:12 pm: |
hel na bro go to best buy and buy the alpine cda-9855 and u will be satisfied i think is better and is available for 300 |
