Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Bass blockers
Author Thread: Bass blockers
Username: Ledzep
does anyone know where i can buy bass blockers that cut from 85hz down? i have a amplified bazooka tube BTA8100 , and its built in crossover cuts at 85hz, yet all i can find in bass blockers to compliment this bass tube only go down to 200hz, which would leave a freq gap between 85hz and 200hz. i found some on ebay, but not impressed with the brand name, sorta generic. got any links that sell 85hz bass blockers ?
Username: Glasswolf
Wisteria, Lane
Post Number: 11244
get a bass blocker at about 100-120Hz.
leave the gap there.
the roll off will cover the gap. the XO point isn't a brick wall cut off. It's just the point where the volume starts to diminish from there on down.
Username: Ledzep
Post Number: 8
thanks glasswolf. do you know where i can get some middle of the road quality bass blockers at that spec?
Username: Glasswolf
Wisteria, Lane
Post Number: 11260
FMOD makes RCA level ones you can order from partsexpress.com or try crutchfield.. or just build your own.
www.the12volt.com has diagrams for 2nd order high-pass filters.
Username: Nypdlapd
Crutchfield is a RIPOFF
Username: Glasswolf
Wisteria, Lane
Post Number: 11271
that they are, but they stock the bass blockers.
I don't buy them pre-made, I make my own crossovers, so I really don't have a lot of info on where to buy the prefab jobs online other than there or other craptacular stores like CC and BB
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Bass blockers [ « Previous ] [ Next » ]
