Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Power/wiring problems with sony
Author Thread: Power/wiring problems with sony
Username: Pdraper
Knoxville, TN
Post Number: 8
I have a Sony CDX-F5705X CD player that I installed in my 1984 Jeep CJ-7. It works fine but sometimes it cuts off then turns itself back on. This usually happens when the volume is high, and once I turn it down, it doesn't do it that much. It also does it sometimes when I shift and the RPMs drop. I tested the alternator, and it works fine. I'm sure it's something to do with the wiring so is there a way i can wire it so it doesn't turn itself off anymore?
Thanks,
pdraper
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Power/wiring problems with sony [ « Previous ] [ Next » ]
