Home > Message Board > Car Audio > Amplifiers > Archive through February 19, 2006
  Thread Last Poster Posts Pages Last Post
ORION H2 12.2 2000 watts rms only gettin 230..HELP! OPINION?B2006-02-19  04:23 ET
Audiobahn amps any good?CadillacDb11 2006-02-19  03:45 ET
Please help build me a systemAnonymous12 2006-02-19  01:58 ET
Amp problems using Ground Loop IsolatorMitchell Stone2006-02-19  01:32 ET
Is this amp any good to push 2 12" alpine type r's???[...Rovin...]2006-02-19  23:51 ET
Amp for type-s??Chauncey Brown2006-02-19  01:08 ET
WIRING TWO MONO AMPSblaine westropp2006-02-19  00:37 ET
Is this amp any good to push 2 12" alpine type r's???CadillacDb10 2006-02-19  00:29 ET
5000 watts with 2 ampsJake Hill2006-02-18  22:29 ET
Fuse HelpJosh2006-02-18  19:40 ET
Jonathan JL 1000/1 settings helpJonathan2006-02-18  18:52 ET
Is it ok to use speaker wire's to RCA input on ampshaun whitaker2006-02-18  17:15 ET
Ground loop isolatorsBrandon2006-02-18  16:38 ET
Hey IsaacJames Longo2006-02-18  16:36 ET
Power rem. attached to a pos. 12 volt output?work?Brandon2006-02-18  16:35 ET
OutputBrandon2006-02-18  16:28 ET
G&S Designs amps?corey gouveia2006-02-18  15:43 ET
WIRING TWO MONO AMPSjoshsurovey@yahoo.co2006-02-18  14:12 ET
What is a HI INPUT +L- +R- on my amp?Jay B.2006-02-18  01:17 ET
Power rem. attached to a pos. 12 volt output?work?Tommy K2006-02-18  01:09 ET
Will my jensen 12 hit 158db ?Josh2006-02-18  01:02 ET
Best HU for AM & MP3 and wiring 2 2ohm kappa 6x9's w/ 2 tweeters...BrAd GiLmAn2006-02-18  00:50 ET
Car Audio BoomboxAnonymous2006-02-17  23:31 ET
What amp for SE 15"Chauncey Brown2006-02-17  20:32 ET
Who thinks this amp and sub are a good pair?shaun whitaker13 2006-02-17  20:10 ET
Home Sub-amplifier with Car subwoofer?Mark S2006-02-17  19:55 ET
Which amp?Chauncey Brown2006-02-17  18:38 ET
Whats a decent cheap amp 300W x 1 @ 2 Ohms?juliob17 2006-02-17  18:22 ET
Viper 1200.1 and sub(s)juliob2006-02-17  18:15 ET
Please give some opinions about MotorjoyJohn2006-02-17  12:33 ET
Glasswolf, Rovin, Chauncey..... HELP!!!!Liqdfire313 2006-02-17  09:26 ET
HifonicsJosh2006-02-16  23:32 ET
600w mono amp?Chad Lee22 2006-02-16  23:30 ET
For your viewing pleasure...Thomas White21 2006-02-16  22:12 ET
New Soundstream?Jeff Lackman2006-02-16  21:57 ET
What amp?terrence schoelen2006-02-16  21:44 ET
1 Ohm or 4 Ohm which is better?Polo31 2006-02-16  21:22 ET
I know Thump amps suck but..Mitchell Stone2006-02-16  20:52 ET
Sub section is not working..........AgainBrandon2006-02-16  20:24 ET
600w mono amp?killer2006-02-16  19:47 ET
1 12" Infinity 1240W 300 RMSjuliob10 2006-02-16  18:56 ET
Need amp to push 2kw plusJosh10 2006-02-16  14:40 ET
Who thinks this amp and sub are a good pair?shaun whitaker2006-02-16  14:31 ET
Dynamic power?GlassWolf2006-02-16  14:00 ET
Memphis Amplifiers - 4SALEB2006-02-16  11:45 ET
Rockford T10001bd .vs. kicker kx1200.1myuh lope2006-02-16  08:59 ET
What kind of amp for 2 6x9's and 2 5"1/4's?B2006-02-16  00:30 ET
Amp problemb p2006-02-15  22:26 ET
How do i choose a amp to match my sub?Bob36518 2006-02-15  22:06 ET
What's wrong with this E-bay listing?Polo2006-02-15  21:57 ET
Amp F/S700032006-02-15  20:33 ET
Kappa 693.7i 6x9 3-WAY have dual voice coils and want to add anoth...BrAd GiLmAn2006-02-15  19:49 ET
What is the perfect amp for two cvr 12"Night Mirage14 2006-02-15  19:38 ET
Orion 1200d....Marcus Thompson2006-02-15  18:06 ET
New System almost Complete / Mo's SystemJames Longo25 2006-02-15  16:10 ET
Good class ab amp for midsJames Longo13 2006-02-15  15:59 ET
Jl Audio Questionty mutlow2006-02-15  15:04 ET
05 Chevy Blazer Wiring DiagramAtfdmike2006-02-15  11:44 ET
Which Amp is better?Chauncey Brown2006-02-15  11:28 ET
What gauge wire for 1200 watt amp?GlassWolf2006-02-15  07:28 ET
Which Amp to getChauncey Brown2006-02-15  01:24 ET
Good amp for re mt 15'sChauncey Brown12 2006-02-15  01:17 ET
Memphis ampsBob3652006-02-15  00:38 ET
Eclipse AmpsJake Hill2006-02-15  00:24 ET
Jl audio 500/1 recomended subs?gorillapimping14 2006-02-14  23:08 ET
Capacitor & gauge wire help!GlassWolf2006-02-14  22:25 ET
Bass Knobsucfsaxman2006-02-14  18:42 ET
JL 500/1 on A 12w7ucfsaxman2006-02-14  18:37 ET
Kenwood KAC-9152D opinons?shaun whitaker2006-02-14  18:08 ET
Power wire installationMarcus Thompson2006-02-14  18:04 ET
Pg or audiobahn amp juliob2006-02-14  17:41 ET
How to replace transistors?Stevie doo2006-02-14  16:28 ET
Possible? 2 amps to each voice coil on one DVC sub??GlassWolf2006-02-14  15:43 ET
Should i get 1 or 2 amps??ty mutlow15 2006-02-14  15:07 ET
How to set the bass boost on a ampB13 2006-02-14  14:42 ET
Whats the best distrabution box?B2006-02-14  12:54 ET
How to wire remote-wire in dual-amp setupOptidriven2006-02-14  09:57 ET
HiFonics BX1605D or HIFONICS BX1205D 1????Rosie2006-02-14  09:52 ET
Ebay seller warning!!!!!!!!!!!Isaac11 2006-02-14  08:49 ET
Is the Viper D1200.1 over/underrated?Jake Hill2006-02-14  08:16 ET
Need info about ampsty mutlow2006-02-14  06:32 ET
Anyone bought a refurb amp from Ikesound?|\/|aTT |F2006-02-14  02:42 ET
F/S SX1250.1 Amps Polo2006-02-14  00:46 ET
Subs cutting off?justin gholson2006-02-14  00:19 ET
Ma audio ma5082hx 4000 wattsredbone2006-02-13  23:35 ET
Burnt soundstream amp..CHRISTOPHER jAMES cA2006-02-13  21:59 ET
Problems with my systemjerrime hughes2006-02-13  21:56 ET
Amplifier listing on ebay,what's wrong with it?Polo2006-02-13  21:50 ET
Amp suggestion for 2 300w rms subs[...Rovin...]2006-02-13  21:15 ET
New at this, need help as to what amp to buy[...Rovin...]14 2006-02-13  21:08 ET
Rovin, glass, others[...Rovin...]2006-02-13  19:22 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Amplifiers > Archive through February 19, 2006 [ « Previous ] [ Next » ]
