Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Pre out Voltage
Author Thread: Pre out Voltage
Username: Ergodyne
Post Number: 30
how much, or what kind of difference would i notice from a head unit with 2V pre outs and one with 5V pre outs?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 1093
theres been several threads about this topic.
basically, the higher the voltage, the better/stronger the signal will be when it reaches your amplifier. also, the amp doesn't have to have the gains turned way up to reproduce the sound, lower the gains the better. you'll get better SQ and more detail from a higher Pre out voltage.
i don't know if you can actually hear the difference or not though.
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Pre out Voltage [ « Previous ] [ Next » ]
