Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Clifford alarm/immob would disable.. ...
Author Thread: Clifford alarm/immob would disable.. Help!!!
Username: Simonscott75
I have a Clifford Concept 100 alarm/immob fiited to my car. The alarm had been working without any problems for about two years. Then the car was off the road for about six months, now the alarm will disarm but will not start, basically the alarm/immob has not disarmed all points. I believe its a 3 point immobiliser, I know it releases the fuel pump as I can here it switch on. I have tried resetting the system but no luck. Can any one help in either tell me on the get the system to work correctly. Or just telling me the easiest way to deactivate the whole system. I am not bothered if it does not work any more I just want to get the car started.
Thanks in advance
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Clifford alarm/immob would disable.. ... [ « Previous ] [ Next » ]
