Thread: 2 Amplifiers 1 Preout |
Usman |
| Posted on Wednesday, February 19, 2003 - 08:59 am: |
I need some help here. I was wondering if 2 amps can be run from a head unit that only has 1 preout. I have a Earthquake 250tx which i want to use to power my subs, and a cheap jackson amp which i want to use to power my 6*9 speakers. I have a sony XRC5300R which only has one preout. Can this be done, and if it can how do you do it? Thanks |
Anonymous |
| Posted on Friday, February 21, 2003 - 04:49 am: |
hey man no problem just get a two way electronic cross over which lets you plug in one set of r.c.a. jacks with 2 out puts, 1 for highs and the other for lows and all you have to do is adjust the setings for your lows 50hz-180hz and highs 2k-200k. |
usman |
| Posted on Friday, February 21, 2003 - 07:23 am: |
nice one man. are these crossovers expensive, and do they differ in quality or are they all the same, basically should i go for an expensive one or will a cheap one do the job |
| Posted on Thursday, March 13, 2003 - 11:03 pm: |
usman, check out www.audio-warehouse.com for a decent deal on crossovers. Look for one that has rotary adjustment knobs instead of slide switches...more flexability. I use a Pyramid and it works great, Legacy (pyramid relabeled) has just what you need: http://www.audio-warehouse.com/detail.asp?mdl=LXR4 good luck! |
