Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Entering Ford Radio Code M Series
Author Thread: Entering Ford Radio Code M Series
Dantheguest
Hello all,
I disconected the battery from my radio and now i cannot enter the code into it that I have.
The radio is from an old 1992 ford granada. The radio is (i think) a Ford model 2005, serial # begins with an M.
I have the code for it, but upon trying to enter it nothing happens when I press any button at all.
I'm not sure what's going on.
Any ideas?
Username: Illuminator
Post Number: 2668
You'll have to call a Ford dealership.
fordcodes
Try http://www.decodemyradio.co.uk
failing that you can post it into www.radio-code.co.uk for decoding or use our automated system in seconds.
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2006 > Entering Ford Radio Code M Series [ « Previous ] [ Next » ]
