Thread: Can anyone tell me the difference, if any.... |
Bronze Member Username: Wolfman1966
WEST MONROE ,
LOUISIANA
Post Number: 47 Registered: Jan-06
| Posted on Thursday, February 16, 2006 - 11:56 am: |
between the Pioneer DEH-P4800MP and the Pioneer Premier DEH-480MP....I assume since they both have a P before the number, that they are both Premier....but are they the same radio? |
WEST MONROE ,
LOUISIANA
Post Number: 48 Registered: Jan-06
| Posted on Thursday, February 16, 2006 - 12:15 pm: |
Just looked at www.pioneerelectronics.com and there are a FEW differences...The 4800 is NOT a Premier has a "Subwoofer Direct Control Key" that the 480 does not. The 480 is a Premier, has 4volt,100ohm Preout Voltage and Impedence (compared to 2volt,1k ohm for the 4800), has a 2year warranty(1yr for4800), and has "Premier Service and installation". So NOW what I need to know...is the 480 a better deal. as there is not much difference in price, AND I can get the 480 at a local sound shop, have it installed by them, and get the 2yr warranty. |
Gold Member Username: Tjmutlow
Post Number: 1491 Registered: Sep-05
| Posted on Thursday, February 16, 2006 - 02:02 pm: |
yes. |
georgie1 Unregistered guest |
| Posted on Tuesday, February 28, 2006 - 04:39 am: |
ty mut is wrong. the sound quality is by far different. |
Silver Member Username: Greeney1888
Maple Grove,
MN
United States
Post Number: 178 Registered: Feb-06
| Posted on Tuesday, February 28, 2006 - 04:50 am: |
explain yourself georgie1 |
WEST MONROE ,
LOUISIANA
Post Number: 49 Registered: Jan-06
| Posted on Thursday, March 02, 2006 - 08:51 pm: |
huh,I would think that a Premier would definately be better than a regular Pioneer,and 4volt pre-out would be better than 2.2volts...ty was agreeing. so yeah, explain yourself georgie1 |
Post Number: 1528 Registered: Sep-05
| Posted on Friday, March 03, 2006 - 09:08 am: |
First off, I said yes to the 480 being a better deal bought and installed for the 2 yr warranty. |
