Thread: Fosgate P6001bd |
New member Username: Mrstrike
Post Number: 1 Registered: Feb-06
| Posted on Sunday, February 12, 2006 - 06:04 pm: |
I recently bought the P6001bd and I am curious about a few things. This is a Mono amp yet it has two inputs for the subs. I understand that internally the signal is parallel. Here is my question. Can I run two subs in to the A channel and if so will it break it down to a 2ohm load or will I need to use both channel A and B and leave it at 4ohm. The subs I own are 12 inch Alpine Type E's. Any advice would be great. Here is the amp home page http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6 &family_id=19&item_id=96761&locale=en_US |
Silver Member Username: Young_james
Post Number: 801 Registered: Sep-05
| Posted on Sunday, February 12, 2006 - 08:23 pm: |
the 2 inputs are there to make wiring a 2ohm load much easier. Plug one sub into channel A, and the other sub into channel B, then BAHM! you have a 2ohm load!  |
Gold Member Username: Tjmutlow
Post Number: 1450 Registered: Sep-05
| Posted on Sunday, February 12, 2006 - 08:29 pm: |
as long as they are single 4ohm it works like that... |
Post Number: 806 Registered: Sep-05
| Posted on Monday, February 13, 2006 - 02:19 pm: |
my bad, forgot to mention that!  |
