Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > What type of amp should i get????
Author Thread: What type of amp should i get????
Username: Tommy23
hey alright well i ahve a 96 grand cherr w the infinty sound and im using teh alpine cda-9853 head.. i just bought two alpine type r speakers for th back.... im going to buy a kicker S15L7 soon but i need to know wat amp i should get and if i should get 4 ohm or 2 ohm sub?? can some one please help me
Username: Frobro
Whitehall , MT
Post Number: 10
have you ever herd of sound stream robacons thay where mad befor sound stream whent cheap but you can find them on ebay thay are cheap and never over heat. over 100db to noise ratio but id get 1 1000 watt 2 chanel and a 600 watt 4 chanel and id run a 2 gage wire to a destrebuter and brack it down to 2 4 gage wires
Username: B101
Queen City, NC
Post Number: 1034
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5866384558%26&sspagename= STRK%3AMESE%3AIT%26
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > What type of amp should i get???? [ « Previous ] [ Next » ]
