Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Single channel mono block help
Author Thread: Single channel mono block help
Username: Carajean
Post Number: 14
Ok i blew my amp a while back and got help here to finally determine i did blow it. ok now i go the guy to replace the amp. he gave me a sinle channel mono block. so i hooked everything up. i twisted my 2 subs speaker wire together and stuck them in. ok i powered up my car and the subs and everything work its just there not as loud as before no where near as loud. now i want to know what just might be the problem this time. i did make sure the same wires were in the same place.
Username: Carajean
Post Number: 15
http://www.audioclubhouse.com/proddetail.php?prod=UL1600M&cat=247
my amp
http://www.massiveaudio.com/lowband/products/subwoofers/performance/pw-12.html
my subs i have two 12's.
Username: Tjmutlow
Post Number: 1441
Sorry to say, that amp and those subs are really not compatable, you need a 1ohm mono amp, not a 2 ohm. if those subs are wired to a 1ohm load, your prob going to burn that amp up. the onlu way that would work is to run it at a 4ohm load and then you may only be seeing 150w to each sub.
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Single channel mono block help [ « Previous ] [ Next » ]
