Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Kicker 1200.1 for speakers+comps+twee...
Author Thread: Kicker 1200.1 for speakers+comps+tweets?
Username: 2icey
ANAHEIM, CA
Post Number: 39
im usin a kicker 1200.1 and i have two kicker CVR 12s hooked up to it.
im gonna get four new 4x6s and two tweeters, is there anyway i can hook all of those speakers up to the amp?
Username: Blainew
Post Number: 929
its a 1 channel amp
you want a 4 channel amp
Username: 2icey
ANAHEIM, CA
Post Number: 40
well i have the kicker 1200.1 under my drivers seat, i guess i could put another one under my passengers seat, but what amp would you reccommend?
Username: Homegrowncam
Watauga, TX
United States
Post Number: 177
Depends on what kind of spekers to know the power output needed.
Username: 2icey
ANAHEIM, CA
Post Number: 41
the four 4x6s i have now aren't running off the amp, couldnt i just replace those and they'd work?
Username: Tjmutlow
Post Number: 1425
alot of power for those cvrs, and you will nedd another amp to run those 4x6's
Username: Glasswolf
Wisteria, Lane
Post Number: 11051
get another kicker amp rated at 50 watts RMS x 4 channels @ 4 ohms.
the 1200.1 is for subs only. it's a class D amp so it can't play anything above about 200Hz.
you really do need a separate amp for those 4x6s.
I'd also recommend skipping the separate tweeters unless they come with the 4x6s and their own crossovers. Just get good 4x6 plates instead like the Infinity Kappas for the front, and 4x6 coaxials for the rear.
Username: 2icey
ANAHEIM, CA
Post Number: 44
which amp would you recommend that would get the job done?
Username: Glasswolf
Wisteria, Lane
Post Number: 11058
go to www.kicker.com and find one with those specs.
I don't keep up with all the companies' models every year.. they change too often and I'm getting too old. heh
Username: Safe_cracker
Chicago, IL
US
Post Number: 155
Funny, you are the same age as me and I am in no way OLD, LOL!! :-O
Username: 2icey
ANAHEIM, CA
Post Number: 45
http://cgi.ebay.com/INFINITY-KAPPA-462-7cfp-4x6-2-WAY-160W-SPEAKERS_W0QQitemZ586 5136829QQcategoryZ14939QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
so those are the speakers i should get for the front?
why does everyone like infinity compo.?
what would you reccommend for the back?
Username: Glasswolf
Wisteria, Lane
Post Number: 11070
feel old. been doing this for 15 years now, and after three organ transplants, you'd feel old, too. :P
anyway infinity's kappa and kappa perfect series compos are very good speakers. fairly priced and well made. they tend to be aggressive and bright though, bt many people like that. Personally I prefer a more laid back, smoother speaker like DynAudio or Rainbow, but they come at a steeper price. Some people find the Dyns to be too "flat" because they're used to a brighter tweeter.. but I don't overaccentuate the treble so they work great for me.
I used kappa perfects in one of my jeeps and they were terrific.
Username: 2icey
ANAHEIM, CA
Post Number: 46
but the link i posted was the 4x6s they make?
so should i just replace the front ones? and should I get the tweeters in the front two corners of my truck?
Username: Glasswolf
Wisteria, Lane
Post Number: 11076
yeah those 4x6 plates are the best 4x6s I've heard, personally.
hard to find any that sound good but those do.. especially on an amplifier
Username: Tjmutlow
Post Number: 1460
use the plates and use an amp, they are 2ohm speakers
Username: 2icey
ANAHEIM, CA
Post Number: 47
can anyone name a specific amp to use with them?
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Kicker 1200.1 for speakers+comps+twee... [ « Previous ] [ Next » ]
