Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Getting a Panasonic V A 7300U to play...
Author Thread: Getting a Panasonic V A 7300U to play while driving
Username: Keithd45
I just had a Panasonic VAD 7300 installed, and I need to over ride the parking brake, so that it plays while driving. any ideas? I have a 2002 trailblazer without on star
Username: Tjmutlow
Post Number: 1422
ground the parking brake wire.....
Username: Keithd45
I am not tech savy.....or car savy..is that something I can do myself?
Username: Tjmutlow
Post Number: 1435
it is just as easy as finding the wire and grounding to the chasis of the car or to the ground for the radio wire.
Username: Keithd45
thanks.....finally, anyone have any idea what kind of navigation is compatible with this unit?
Username: Tjmutlow
Post Number: 2190
none, panasonic does not make a unit for the states, other then that you have to use the stand alone nav pieces, like magellen or blackbird...
Username: Keithd45
So I cant run a navigation system through it, and see it through the screen? It asks me what output the navigation is plugged in....oh well..
What about the sirius system..best buy or tweeter dont sell the plug in system, any other options?
Username: Tjmutlow
Post Number: 2253
they stopped making a direct plug and play(panasonic) for Sirius, if your looking for one, try ebay for it.
Username: Keithd45
Would this be it? Looks kinda cheap (pricewise)
http://cgi.ebay.com/SIRIUS-PANASONIC-CR-SRF100-NEW-NO-RESERVE_W0QQitemZ973790184 0QQihZ008QQcategoryZ60205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Tjmutlow
Post Number: 2266
you need the srt, not srf, that one is fm modulated
Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Getting a Panasonic V A 7300U to play... [ « Previous ] [ Next » ]
