Thread: Can u bridge 4 channel |
New member Username: Bandit16
Post Number: 9 Registered: Feb-06
| Posted on Saturday, February 11, 2006 - 05:19 pm: |
hey my friend has a alpine 250 watts amp, 4 channel, i know it isnt good but i wanted to help him out cause he has 1 12 inch sub hooked up to it, can u bridge this type of amp. if u can, may someone be able to show a picture of how to do it.. thanks.... another question.... whats the MONO mean in my amp,,, mtx mono 801d but its a two channel amp, i dont get it.... |
Silver Member Username: Blainew
Post Number: 926 Registered: Nov-05
| Posted on Saturday, February 11, 2006 - 05:21 pm: |
mono means one channel. if its a mono, there are not 2 channels and yes you can bridge 4 channel amps...not all of them but some i doubt u can bridge it to 1 channel but you could to 2 channels and run 2 subs on it |
Bronze Member Username: Bandit16
Post Number: 11 Registered: Feb-06
| Posted on Saturday, February 11, 2006 - 05:26 pm: |
ok thanks i have two channels.. and it says on the box mono-block.. i have two subs hooked up |
Post Number: 12 Registered: Feb-06
| Posted on Saturday, February 11, 2006 - 05:29 pm: |
thats my amp.... http://cgi.ebay.com/MTX-New-800-Watt-Mono-Block-Class-D-Amp-Thunder-801D-NR_W0QQ itemZ5863497194QQcategoryZ64573QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: Matt12490
Benicia,
California
Post Number: 384 Registered: May-05
| Posted on Saturday, February 11, 2006 - 05:52 pm: |
no, your amp only has 1 channel |
Gold Member Username: Tjmutlow
Post Number: 1411 Registered: Sep-05
| Posted on Saturday, February 11, 2006 - 06:18 pm: |
it has 2 terminals, makes it easier to wire amp, and you can bridge most 4channel to a 4ohm load only., so either a dual 2 or single 4 for a single sub. |
Post Number: 1412 Registered: Sep-05
| Posted on Saturday, February 11, 2006 - 06:20 pm: |
and with that amp, the best you can see is a 2ohm load, so if you use 2 subs, you need dual 2ohm subs. |
