Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > What is better 4 ohm or 2 ohm subs in...
Author Thread: What is better 4 ohm or 2 ohm subs in my situation
Username: Nyrider
Rochester, NY
Post Number: 8
I have a aw8002t amp now I know it is 800w rms x 1 at 4ohms
and I also have aw8000t amp and I know its 800w rms x 1 at 2ohms. I've heard the lower the ohms the harder it hits. Now my question is even though both equal out 800w rms am I better (say I only want to use one of the 2 amps) using the aw8000t amp with a sub wired down to 2 ohms or the aw8002t amp with a sub wired down to 4 ohms OR are they the same. This is something that confuses me. Any help??? Please Please
Username: Blainew
Post Number: 911
same thing
Username: Nyrider
Rochester, NY
Post Number: 9
Thank you for clearing that up for it was one of things
Username: Tjmutlow
Post Number: 1403
if you use the 8002, then dual 4, the 8000t dual 2
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > What is better 4 ohm or 2 ohm subs in... [ « Previous ] [ Next » ]
