Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Enough power for my components??
Author Thread: Enough power for my components??
Username: Goinglow
Post Number: 9
I'm looking at running 3 sets of diamond audio.
For the front I'm looking at the D661s powered by D3400.2.
For the kickerpanels I'm looking at running D651i, and for the rear I'm looking at running D651s powered by a D3400.4.
Problem is I am underpowering the speakers with the 3400.4 since its rated at 50x4 RMS and those speakers are rated at 80RMS.
The fronts should be matched up perfectly.
Will this still be a good setup even tho I'm underpowering them??
Username: James1115
Ct
Post Number: 4983
yes it will be fine that amp isa rated at 12 volts also so you should be right on the money.
Username: Goinglow
Post Number: 10
sounds good the only other question i thought of was is there going to be a problem with my sound since i will be running my kickpanel speakers and my rear speakers off the same amp which will hook into the rear rca output on the headunit
Username: Goinglow
Post Number: 11
anyone???
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Enough power for my components?? [ « Previous ] [ Next » ]
