Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > 3 amps 3 subs one preamp what to do
Author Thread: 3 amps 3 subs one preamp what to do
Username: Itslucifer80
ok i am getting 3 vega v-maxx 2 4ohm vc and i have a deh-8600 head unit well i have been tring to find out what amp/amps i should use i was told 3 amps so i thought the audiobahn a8000T 800 rms each 3 of em well the problem is how to get the signal to them? i mean i can split it off and make/buy a 3-->1 rca plug but what else can i do any mono amps of just looking for some ideas
Username: Glasswolf
Wisteria, Lane
Post Number: 11000
daisy chain the amps, use splitters, or use an external electronic crossover.
ok would thoses amps be enuff power for those subs the amps say 800 rms @ 2 ohm and the subs are rated 600 rams @ 2 ohm?
rms not rams
Username: N2audio
Lawrence, Ks
Post Number: 556
plenty of power
those amps have rca outputs so I would just daisy chain them as GW suggested. Rca's in to 1st amp, 1st amp out to 2nd amp, 2nd amp out to 3rd.
Username: Rovin
Trinidad & T...
Post Number: 5439
I'm just wondering here but -
if each of those subs are 400 wrms then buy a phoenix gold xenon 1200 amp which does 1200 wrms between 1-4ohms - this might be the easiest solution by using this 1 amp alone & the cost of it would = 3 of those ABahn amps ......
Username: James1115
Ct
Post Number: 4984
those subs are 600 rms he has the new ones.
Username: Rovin
Trinidad & T...
Post Number: 5441
OH , ok - i thought it was the older 400wrms model...... Upload
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > 3 amps 3 subs one preamp what to do [ « Previous ] [ Next » ]
