Thread: Need an amp suggestion |
New member Username: Nextgengamere3
NYC,
NY
Post Number: 1 Registered: Feb-06
| Posted on Friday, February 10, 2006 - 12:20 am: |
I'll be using it to push 2 12" W3's (maybe 3 W3's in the future) I was thinking the 500/1 by JL would be my best bet? |
Silver Member Username: Blainew
Post Number: 905 Registered: Nov-05
| Posted on Friday, February 10, 2006 - 12:49 am: |
jl amps r some of the the best...if u have the money then yes |
Gold Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 5184 Registered: Jul-05
| Posted on Friday, February 10, 2006 - 12:53 am: |
what are the vc configs |
NYC,
NY
Post Number: 2 Registered: Feb-06
| Posted on Friday, February 10, 2006 - 01:27 am: |
http://www.the12volt.com/images4/woofer_wiring/cropped/2_2ohm_dvc_2ohm.gif |
Huntsville,
Alabama
U.S.
Post Number: 5201 Registered: Jul-05
| Posted on Friday, February 10, 2006 - 01:47 am: |
ok this would save u a ton of money without sacrificing quality http://www.ikesound.com/product-product_id/2424 When u have 2 u could wire it at 2ohms and when u add the 3rd u could just wire it down to 1.34 ohms, since the amp is 1 ohm stable it will be perfect.. Same company makes orion and directed |
NYC,
NY
Post Number: 3 Registered: Feb-06
| Posted on Friday, February 10, 2006 - 04:09 am: |
Never heard of Viper. |
Huntsville,
Alabama
U.S.
Post Number: 5236 Registered: Jul-05
| Posted on Friday, February 10, 2006 - 04:13 am: |
Have u heard of Orion or Directed, the same exact company, they push there rated power and it will not bust ur wallat. Those are dvc 2 ohm subs right??? |
NYC,
NY
Post Number: 4 Registered: Feb-06
| Posted on Sunday, February 12, 2006 - 12:45 am: |
I mean I've got $400 bucks to spend on an amp, I'd like to get the best for it y'know? So with an amp reccomendation, can I also get a sub wiring reccomendation to maximize the SQ/SPL? |
Gold Member Username: Tjmutlow
Post Number: 1429 Registered: Sep-05
| Posted on Sunday, February 12, 2006 - 07:38 am: |
If your going to buy another dual 2ohm sub, you need an amp that is 1ohm stable, those will get down to 1.333ohms. alos you do not need a ton of power to run them, maybe a 800w class d. ir un 1 of those in my wifes altima, with a 250/1 and gain turned down and it is terrific. So maybe an Orion 800d or even that viper. |
