Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Finding the right amp
Author Thread: Finding the right amp
markho311
I'm looking into buying an RE Audio 12" SE, its dual 4 ohm and runs at 600 watts RMS, I was having trouble finding an amp to use with it at a good price and wondered if anyone could help with some suggestions.
Username: Blainew
Post Number: 878
save some money...get two of those and and RE12.1
you wont be dissapointed
markho311
i'm on a bit of a budget squeeze right now so i'll only have enough for the one sub and an amp at the moment
Username: Blainew
Post Number: 880
well your going to need to get one that does 600 RMS at 2 ohms
i think the last year kickers were stable at 2 ohms, other than that look at orion, or hifonics
Username: N2audio
Lawrence, Ks
Post Number: 549
This is certainly worth considering.
http://ikesound.com/product-product_id/3852
markho311
you think a profile AP 1200 would work?
Username: N2audio
Lawrence, Ks
Post Number: 551
A lot of people on this forum like to discard Profile as junk, but I think they're full of themselves. Very good budget amps IMO.
However, with your one 600w DVC4 there is a better option than the ap1200. With a 2 ch amp the best you could do would be to wire the coils in series for an 8 ohm load bridged. That would result in about 400w from the ap1200.
With the AP1000M you could wire your coils parallel for 2 ohms and get 500w for a few $ less than the 1200 (at least at millionbuy.com). Not a big difference, but more power for the same or less money is always a plus.
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > Finding the right amp [ « Previous ] [ Next » ]
