Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > 12" to 15"
Author Thread: 12" to 15"
Username: Moey
Sydney, NSW
Australia
I just recently changed from using 2 12" pioneer subs to 1 15" kicker sub. I noticed that alot of the higher frequency bass is much weaker from the kicker than from the pioneers. Im sure this is because of the fact that its a 15" sub. My question is, is there anyway to make it hit those higher freq. bass notes better or is it stuck like that?
Thanx...
Username: Kd7nfr
Montpelier, ID
United States
Post Number: 1432
What's your enclosure specs. and amp?
Username: Moey
Sydney, NSW
Australia
Sealed enclosure (not sure exactly how big the box is), running off a kicker kx400.1
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 587
you should check the settings on your amp try adjusting those if that doesn't work it could be the sub itself or the volume of the box that prevents it from hitting the high frequencies.
Home > Message Board > Car Audio > Amplifiers > Archive through February 13, 2006 > 12" to 15" [ « Previous ] [ Next » ]
