Thread: What is a good inexpensive amp for my subs? |
Bronze Member Username: Wolfman1966
WEST MONROE ,
LOUISIANA
Post Number: 35 Registered: Jan-06
| Posted on Tuesday, February 07, 2006 - 02:21 pm: |
I am going to buy 2-kicker comp 10's (150watt srms 300watts max) which of the following would be a good inexpensive amp to power them? Profile AP600 Directed 600D Directed 750D...I can actually get it cheaper than the 600D. Kicker 600MXS...which I have to find a place that will take money orders for it. Well people what about it |
Gold Member Username: James1115
Ct
Post Number: 4896 Registered: Dec-04
| Posted on Tuesday, February 07, 2006 - 02:44 pm: |
if you can wire them to 4ohms then the directed 600 will work. I have never heard of that kicker model before. I would look at the kicker kx 600.1 that would work at 4 ohms also. at 2 ohms they are too powerfull so you will need a much smaller amp. |
Gold Member Username: Tjmutlow
Post Number: 1379 Registered: Sep-05
| Posted on Tuesday, February 07, 2006 - 03:03 pm: |
750d and keep gain set correctly, if those are dual 4 subs. |
Silver Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 105 Registered: Jan-06
| Posted on Tuesday, February 07, 2006 - 04:03 pm: |
Stick with the kicker amp. Polo.. |
WEST MONROE ,
LOUISIANA
Post Number: 39 Registered: Jan-06
| Posted on Wednesday, February 08, 2006 - 10:40 am: |
OK, I don't think they are dvc's but they are 4 ohms...any other ideas on a good mono amp...since these are too powerfull? |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 539 Registered: Mar-04
| Posted on Wednesday, February 08, 2006 - 04:50 pm: |
Comps are svc I like the Profile option, but it would make more sense to me to go with a mono such as the ap700m or HA700m, even the HA1000M if you keep the gain low. All super cheap at millionbuy.com. That kicker deal sounds like a scam. Money orders for an amp that doesn't exist? Bad news. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 2068 Registered: Mar-04
| Posted on Wednesday, February 08, 2006 - 05:19 pm: |
hey michael, i'm guessing you are on a budget...so i would prolly w/ a directed 750d and 2 Single 4ohm comp 10's. http://www.ikesound.com/product-product_id/2119 you can get it here for $79+ship. also...do you know of anyone in the monroe/west monroe area looking for custom sub boxes? i build boxes (ported, sealed, anything) cheap. |
Monroe,
Louisiana
Post Number: 2069 Registered: Mar-04
| Posted on Wednesday, February 08, 2006 - 05:22 pm: |
oh other thing... if you get the directed 750d and later on you decide you want more bass...you could get 2 more comp 10's. you would just wire all 4 10's to the amp and it would be a good match...since you would have 4 SVC 4ohm subs.
Silver Member Username: Terry6405
Sullivan,
IN
US
Post Number: 226 Registered: Sep-05
| Posted on Wednesday, February 08, 2006 - 09:17 pm: |
look at hifonics, great on a budget |
WEST MONROE ,
LOUISIANA
Post Number: 43 Registered: Jan-06
| Posted on Monday, February 13, 2006 - 01:58 pm: |
well, guess I can say "never mind" right now. I've decided to buy a good HU instead. You can see my post in Head Units section....Looks like I will be going with Pioneer Premiere |
