Thread: Is there a fuse you can pull to make your trunk only open to a key?? |
Silver Member Username: Goatin
U.S.A
Post Number: 150 Registered: Jan-06
| Posted on Saturday, February 04, 2006 - 10:30 pm: |
is there a fuse you can pull to make your trunk only open to a key or any other ways to dissable the power trunk opener |
Bronze Member Username: Catalin
Surrey,
BC
Post Number: 62 Registered: Nov-05
| Posted on Monday, February 06, 2006 - 02:27 am: |
What kind of vehicle? Year/make/model? |
monsterinmypants Unregistered guest |
| Posted on Monday, February 06, 2006 - 07:49 pm: |
disconnect the power trunk release.. at the trunk!! year/make/model.. PAH!!
| Posted on Sunday, February 12, 2006 - 11:43 am: |
and I love the da big schlongs in my mouth!!! |
New member Username: Ruthlessryda
Post Number: 6 Registered: Feb-06
| Posted on Sunday, February 12, 2006 - 08:49 pm: |
just cut the positive wire on the solenoid, or find the fuse for it at your fuse box, or find the switch and cut the positive behind it. |
Morrowb Unregistered guest |
| Posted on Sunday, February 12, 2006 - 11:14 pm: |
If i was a theif and wanted your subs and i tried the electric trunnk release the first thing i would check is the fuse. Try another approach, on my cavalier i clipped the cable on the trunk for the key to open it and but hid the button under my seat. |
