Thread: Seperate display navigation unit? |
Bronze Member Username: Travis_lamance
Post Number: 11 Registered: Feb-06
| Posted on Saturday, February 04, 2006 - 01:57 pm: |
Are there any navigation deals that I can plug into an existing monitor via rca or someother? Thanks |
New member Username: Redlightmatt
Halifax,
Noiva Scotia
Post Number: 1 Registered: Mar-06
| Posted on Monday, March 20, 2006 - 05:36 pm: |
Hi, did anyone ever give you an answer? I'm looking for the same thing. |
Seattle,
WA
Post Number: 15 Registered: Feb-06
| Posted on Thursday, April 06, 2006 - 04:09 pm: |
no help from here, I did find a couple though, I don't remember one of them, but this one looks like it'll do the trick: Kenwood KNA-DV4100 http://www.american-tiger.com/index.asp?PageAction=VIEWPROD&ProdID=239 |
Seattle,
WA
Post Number: 16 Registered: Feb-06
| Posted on Thursday, April 06, 2006 - 06:08 pm: |
The other one was the PLDNVD95 by Pyle. It's quite a bit cheaper. It's usually pictured with a monitor, but I'm pretty sure it can be used with a seperate monitor. http://www.mobilevideozone.com/product_view.aspx?product_ID=47AD032C-D726-4001-A E81-BD429F9B36C7 |
Halifax,
Noiva Scotia
Post Number: 2 Registered: Mar-06
| Posted on Friday, April 07, 2006 - 09:06 pm: |
Thanks for the help. Matt |
Gold Member Username: Tjmutlow
Post Number: 1868 Registered: Sep-05
| Posted on Saturday, April 08, 2006 - 07:28 am: |
the kenwood i believe only works with kenwood radios, |
Silver Member Username: Ironslave
Offutt AFB,
Nebraska
U.S.A.
Post Number: 446 Registered: Sep-05
| Posted on Monday, April 24, 2006 - 05:21 pm: |
any other suggestions?
Seattle,
WA
Post Number: 18 Registered: Feb-06
| Posted on Sunday, June 18, 2006 - 10:48 pm: |
reguarding the kenwood: "or with the optional KNA-RC300 remote control you can use the KNA-DV4100 with any mobile TV" I found one more for anyone that might be interested, the Alpine NVE-N852A |
