Thread: Having problems with kenwood kvt-717 please help |
New member Username: South305
KEY WEST,
FL
Post Number: 1 Registered: Feb-06
| Posted on Friday, February 03, 2006 - 03:57 pm: |
i was trying to install a kenwood kvt-717 unit in my car. i had everything ( it seemed ) connected right. the unit was working perfect , so i installed it into the dash and turned the key and there was no power to the unit ? i checked the fuses on the cables and they were good. could there be another fuse somewhere i missed ? please help.. thanks eric , fl |
New member Username: Mrcali4u
| Posted on Monday, February 27, 2006 - 06:29 pm: |
i have no idea, but can you help me out i need a copy of the kvt 717 manual, i need the default security code, would be help full. |
Silver Member Username: Islandboy808
Mililani,
Hawaii
US
Post Number: 667 Registered: Nov-05
| Posted on Wednesday, March 01, 2006 - 02:38 am: |
try and check if u have the remote wire hooked up correctly |
