Home > Message Board > Car Audio > Multimedia Systems > Archive through March 19, 2006 > Jvc witha 3.5 inch screen
Author Thread: Jvc witha 3.5 inch screen
Username: Curious
Post Number: 10
Hey guyz jus wondering what you all think about the jvc head unit with the 3.5 inch screen my friend is selling his for around 250 to 300 and it is practically brand new the picture looks pretty clear and will it fit in 2002 dodge stratus se four door.
Thanks in advance
J.G
Username: Tjmutlow
Post Number: 1295
its ok and cheap enough
Username: Curious
Post Number: 11
ok thanks
Username: Curious
Post Number: 12
Hey ty are you saying only if it works well and isn't damaged or are u saying it is a cheap system and it would be a bad idea to spend between 250 and 300
Username: Tjmutlow
Post Number: 1309
if it is in good shape and has no p[roblems with it, then get it. its not bad.
Username: Curious
Post Number: 18
OK THANKS
Home > Message Board > Car Audio > Multimedia Systems > Archive through March 19, 2006 > Jvc witha 3.5 inch screen [ « Previous ] [ Next » ]
