Thread: How do u hook up Overhead Monitor |
Bronze Member Username: I8eb4
Post Number: 19 Registered: Jan-06
| Posted on Tuesday, January 31, 2006 - 05:01 pm: |
how do u attach a Overhead Monitor to your roof |
| Posted on Saturday, February 04, 2006 - 09:01 pm: |
Silver Member Username: Islandboy808
Mililani,
Hawaii
US
Post Number: 609 Registered: Nov-05
| Posted on Sunday, February 05, 2006 - 05:54 am: |
u have to drop down the headliner |
Gold Member Username: Tjmutlow
Post Number: 1347 Registered: Sep-05
| Posted on Sunday, February 05, 2006 - 06:26 am: |
no you don't on almost all vehicles, what type of car is it? |
bryan stonebrokler Unregistered guest |
| Posted on Sunday, February 05, 2006 - 07:07 pm: |
a 97 F-150 single cab forgot my password |
Mililani,
Hawaii
US
Post Number: 613 Registered: Nov-05
| Posted on Sunday, February 05, 2006 - 10:22 pm: |
well for mine u had to just a little.i didnt mean drop the headliner all the way down,just a little so u can run the wires.why ty is there an easier way. |
Post Number: 1355 Registered: Sep-05
| Posted on Monday, February 06, 2006 - 07:11 am: |
does it have the huimps near center, if not drop overhaed light if it is near center, use 1/8 or 1/4 wood strips between headliner and roof, then fish a coat hanger from either side of truck to opening (light). mount the bracket to roof, connect the wires(and tape connectionsa) then mount the tv to the bracket. |
