Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Clifford Concept 300 HELP Please!
Author Thread: Clifford Concept 300 HELP Please!
James Newton
Hi, I have a clifford concept 300 alarm and the remote seems to have stopped working, I have changed the battery in the remote and it still does not respond. I only have one remote and the car does not have door handles so I cannot even get into my car to disarm and move the car.
My question; if I get into the car, can I add another remote with out this one working and how?
Username: Nocc1n
US
Post Number: 175
yes you can, just open one door, turn your key to ignition then to off, then hold down your valet switch and hit a button on your new remote. but check your ant. connections first, they might have come unplugged.
James Newton
The alram is currently on, will this effect the procedure?
What is the Valet switch is that the remote?
Thanks
James
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > Clifford Concept 300 HELP Please! [ « Previous ] [ Next » ]
