Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > How hard is this?
Author Thread: How hard is this?
Username: Terry6405
Sullivan, IN
US
Post Number: 202
how hard would it be to install this alarm/rem start on a 89 accord LXI?
http://cgi.ebay.com/2-Remote-Car-Alarm-System-REMOTE-START-Security-System_W0QQi temZ5857990831QQcategoryZ94833QQtcZphotoQQcmdZViewItem
Username: Terry6405
Sullivan, IN
US
Post Number: 203
ive done some research and found out the colors and locations for my car but i am afraid to touch anything for fear of messing up my electrical system, where should i start? what do i do?
Username: Catalin
Surrey, BC
Post Number: 56
I think it will only work with an automatic.
Install isn't all that tough at all.. I have an 86 Accord with an EFI swap from an 89 SEi. I can help you out for sure.
Start by prepping the harness, mounting the control unit, running wires to the locations where they need to be connected, mount LED, mount valet switch, mount the siren, mount the hood pin and test.
That was an example as to how I do my installs.
Any specific questions? I'll do my best to answer.
Home > Message Board > Car Audio > Security Systems > Archive through March 15, 2006 > How hard is this? [ « Previous ] [ Next » ]
