Thread: 2nd Amp |
New member Username: Fordeh
Post Number: 1 Registered: Jan-06
| Posted on Sunday, January 29, 2006 - 07:42 pm: |
i am wondering if any1 can tellme how2 connect a second amp up. i have got a 2 channel 1 in now runnin my sub. how do you all da power cords 4 da second 1 ??? dis amp is 2 run my speakers. |
Gold Member Username: Tjmutlow
Post Number: 1279 Registered: Sep-05
| Posted on Sunday, January 29, 2006 - 08:14 pm: |
use a distribution block and use rcas from behind the radio for the other amp |
Silver Member Username: Phuktupbasshead
Phoenix,
Arizona
United State...
Post Number: 465 Registered: May-05
| Posted on Sunday, March 12, 2006 - 05:06 am: |
But what about the fuse that goes near the battery???? Here's an example: If i have a 900 watt amp (and am using a 100amp fuse near the battery)... then if I use a distribution block, won't I need a higher amp fuse??? I'll need to add the the amp rating of both amplifiers??? (3 30amp fuses on one amp and 2 25amp fuses on the other = total of 140amp fuse near the battery. CORRECT or INCORRECT?) What if i just hooked up the 2nd amp and DID NOT change the fuse near my battery??? Problems? |
Post Number: 1632 Registered: Sep-05
| Posted on Monday, March 13, 2006 - 01:08 am: |
that is enough |
