Thread: Amplifier QUestions |
New member Username: Qdeathstar
Virginia Beach,
VA
Post Number: 3 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 10:36 am: |
OK, first, I have speakers that are 250watts max, 65watts RMS x 4 and i have an amplifier that is 100watt RMS x 4. I was wondering, I heard a bout clipping and overpowering, and I was wondering how i can tune my Amp to prevent this. I dont care about pulling the maximum amount of power out of them, so i'd rather play it safe than sorry.. you know. I just dont want them to burn out. Also, I heard that you need to play them before a week before you turn them up loud? Is this true? Lastly, The amp I have is a 960watt Max 100watt x 4, and i was wondering what amp kit do i need so i can hook up all the speakers and everything with the amp. I heard you should go one gauge up, so i'd like to do that in this case... |
Gold Member Username: Tjmutlow
Post Number: 1259 Registered: Sep-05
| Posted on Saturday, January 28, 2006 - 05:49 pm: |
4guage wiring kit, and to tune it, turn amp all way down, then turn radio just past what you normal listening to or what might be the loudest your going to listen, then adjust the amp to your liking. |
