Thread: Are they gunna BLOW ?? |
Bronze Member Username: Goatin
Post Number: 46 Registered: Jan-06
| Posted on Friday, January 27, 2006 - 11:18 pm: |
Can I hook up 2 750wrms DVC subs to a 1 OHM mono 1500wrms amp? I guess my question is can the subs somehow get overpowered or is the wattage spread evenly over the coils?I can not find anything on this topic.. |
Silver Member Username: Ucfsaxman
Oviedo/orlando,
Fl
Post Number: 556 Registered: May-05
| Posted on Friday, January 27, 2006 - 11:31 pm: |
as long as the subs are wired correctly then you will be fine. the wattage will be spread evenly. |
Post Number: 49 Registered: Jan-06
| Posted on Friday, January 27, 2006 - 11:55 pm: |
Would it be best to wire them in series? |
Silver Member Username: Blainew
Post Number: 758 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 12:09 am: |
u wont be able to over power them. are they 2 ohm dvc or 4 ohm dvc |
Post Number: 53 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 12:17 am: |
They are 2 ohm per coil 15" Kicker solo L5's  |
Post Number: 762 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 12:18 am: |
you can wire them together to 2 ohms....not 1 |
Post Number: 54 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 12:23 am: |
So if I find a amp that pumps 1500wrms that is 2 ohms stable it will work fine? |
Post Number: 765 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 12:27 am: |
yea...try kicker...their amps are all stable at 2 ohms instaed of 1..and their O6 lineup is comin out soon..u may be able to get it now im not sure |
Silver Member Username: Cadillacdb
Houston ,
TX
Post Number: 409 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 12:29 am: |
You can wire both subs together for Two ohms not 1 you would need 4 ohms DVC to be able to wire them both together for 1 ohm... http://ikesound.com/product-product_id/2425 The Link above would be my first choice for powering those Subs with, Does 2500@ 2 ohms X 1 its give you lots of headroom as well an its only 355 bucks i dont think you are going to be able to find a better price for an amp that does that much power at 2ohms .. but if you have lots of money buy the kicker Kx2500.1.. but if you dont have lots of money your best bet is the one at ikesound that i gave a link to |
Houston ,
TX
Post Number: 410 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 12:33 am: |
Or you could just look around for somthing that does 1500X1 @ 2ohms but i always like to give myself lots of headroom so thats why i would go with somthing that does between 2000 an 2500 rms at 2 ohms |
Post Number: 767 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 12:41 am: |
2500 RMS would be too much if your subs are only about 1500 RMS if thats the only system youl have and u dont plan on upgrading..i would say to match the RMS of the amp with the RMS of the subs because you know that you will push the subs higher than they should go....who wouldnt use all the watts if they had them.. |
Houston ,
TX
Post Number: 412 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 12:46 am: |
I would still get atleast 500 more then what they need |
Houston ,
TX
Post Number: 413 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 12:52 am: |
Blain BTW what you running now ? still got those Weak Audiobahns with that soundstrom Junk or did you up ur system, i remeber you saying you were changing up but i dont frequent the site so i thought i would ask???? i see that you have learned alot from being around this site, i remeber when you knew nothing at all |
Houston ,
TX
Post Number: 414 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 12:55 am: |
Mitchell ,, How strong of an alternator do you have??? do you know how many amps it is ? |
Post Number: 56 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 12:57 am: |
I found a hifonics 1500x1 @ 2 ohm is hifonics anygood? |
Post Number: 768 Registered: Nov-05
yea man....ive learned soooooo much here....enough to wire the new system in my car...the audiobahns are still in there hahah im upgrading to RE...2 12.1 amps...two 12" SX.....2400 watts RMS... but now i cant really decide if i should get one amp....and two SE's (1200 watts rms) or two amps and two SX's (2400)rms i just dont relaly have a sense of how many watts i want...bc my amp says 1600 watts but its the cheapest amp ever...so who knows what its really puttin out i willprobably end up getting 2 tho..i just dont want a new alt. then after im done with taht ill get some new speakers and a 4 ch. |
Post Number: 769 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 12:58 am: |
yea hifonics is good for the price...not TOP quality...but if u want a little bit cheaper it is the way to go |
Post Number: 57 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 12:59 am: |
106amp stock. For now I am looking. |
Post Number: 770 Registered: Nov-05
get a kicker zx 1500.1 hifonics puts out about 70% of the rated watts |
Houston ,
TX
Post Number: 415 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:01 am: |
If you get an Amp that is CEA compliant an puts out its rated power at 14.4 volts then if your alt isnt strong enough to get ur battery at a constant 14.4 volts when your sysetm is turned up, then your subs are never going to see 750rms each eitherway so the amp you get really doesnt matter unless you Upgarde your alternator |
Post Number: 771 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 01:03 am: |
for every 1000 watts you run..you need about 100amps ive heard that is for test tones tho, and when you arelistening to regualr music abiotu about half that...but imean...i have a 110 amp alt and i have to turn down the system at stoplights bc my voltage meter pulses to the music hahah youll be fine ..but a new alternator in the future would help |
Post Number: 772 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 01:05 am: |
Post Number: 58 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:06 am: |
alternator's I can get for ~$150-$200 amps are an investment. |
Post Number: 59 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:09 am: |
is there any formula for figuring the port size for a sub box? |
Post Number: 773 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 01:10 am: |
haha i let the box making up to klausaudio...so i dont know |
Houston ,
TX
Post Number: 416 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:12 am: |
A 1500rms amp would need atleast 120 amps itself just to put out its rated RMS power.. so with 1500rms you might get away with a 106 amp alt but probably barely, an what i mean by get away with it is that you might not have to worry about waken up almost all the time to a car that wont start because you ran your system the other day, but it will probably only keep your battery right above the point of death, like probably around 12 volts is what it will stay at but 12 might not kill the battery unless it goes below that a few times but 12 volts wont let an amp thats rated for 1500 at 14.4 volts make 1500rms |
Post Number: 61 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:16 am: |
How many amps does a car use at full load? |
Houston ,
TX
Post Number: 417 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:18 am: |
its said that the car itself uses around 60 percent of the output of the alt |
Post Number: 775 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 01:19 am: |
im not sure....but unless u got the $ dont buy a new alt. until you need it.i mean...your not gonna be listening to the system allll the way up ..allllll the time |
Houston ,
TX
Post Number: 418 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:21 am: |
at idle the engine uses less but at idle the alternator also puts out less.. so if you have a 1500rms amp i wouldnt advise sitting at idle running your system at full blare |
Post Number: 62 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:22 am: |
How do you think one of these would sound in a 6 cubic foot box? |
Houston ,
TX
Post Number: 419 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:26 am: |
Mane , you probably couldnt even turn ur stereo up past 35 or so without bringin your battery down to 11 volts while sitting at an idle.. an the battery will come back from going that low only a hand full of times so if you keep doing that to your batterys ur just gonna be getting new ones all the time because the ones you have wont be accepting a charge any longer |
Post Number: 63 Registered: Jan-06
| Posted on Saturday, January 28, 2006 - 01:33 am: |
So if I were to get a 160amp alt. I could run it full blast all the time except at idle without hurting anything? |
Houston ,
TX
Post Number: 420 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 01:54 am: |
Yeah, it might not stay at 14.4 but it will stay in the 13 volts area which is fine, an if you still wanna use it when sitting at idle just put a yellowtop under the hood because even if you bring that thing below 11volts as long as you turn off the stereo an you let the battery charge back up off the alt for a while before truing off the car then you shouldnt have to worry about anything |
Houston ,
TX
Post Number: 421 Registered: Aug-05
| Posted on Saturday, January 28, 2006 - 02:21 am: |
Now Blaines heart is in the right place but he hasnt had any real life experience with a very power comsuming system, hes just going on what hes heard an read but ive had systems kill me so i know.....My first couple of systems werent much power wise then i got a decent system in my 87 Cadillac fleetwood an it killed me, it was a RF T10001BD an i had it wired to two subs at 1 ohm mono an it was rated to put out 1000rms at 1 ohm but the Birth sheet said it did 1450 at 1 ohm so it was doing some where around 1400rms an the alt was 110amps an it couldnt cut it, my car was always dead so i got the alt tested an they said it was working so i knew what my problem was an i bought a 180amp alt off ebay an didnt have any further problems but then i got different subs and a second T10001BD an again i started haven power consumption problems so i had to add two yellow tops one under the hood an one in the trunk... then i got a Second car ( A 96 Cadillac Seville ) an i got two Subs an a Audiobahn A2300HCT amp an This car has a 140amp alt on it an the subs were only wired to the amp for 2 ohms so one to each channel should have only been pulling 1200rms total but still the 140amp alt couldnt cut it so i put one yellow top under the hood an a Cap an now its been staying above 12 volts but its still isnt enough an i recently bought 2 Orion 2500Rms amps an i ordered a 300Amp alt so ill be putting that in soon an now i just gotta figure out which subs i wanna use with my new Orion amps |
Post Number: 781 Registered: Nov-05
| Posted on Saturday, January 28, 2006 - 01:36 pm: |
two 2500d's? dammmmmmmmmmmmmmmmmmmmmmmmmmmmmmm |
