Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp help
Author Thread: Amp help
Username: Luke5513
Post Number: 26
the problem is I have infinity kappa perfect 6.5 components in the front "100 rms" and infinity kappa 2 way in the back "55 rms" I need one amp to rum them, I have a truck and don't have the room for two more amps. If I buy a 100x4 the rear over powered and if i get a 50x4 the front is under powered. thanks
Username: Rovin
Trinidad & T...
Post Number: 5074
here's an option - well what u can do is get an amp like my alpine F545 which has separate gains for channels 1/2 & 3/4 so can adjust the gains 4 ur case so it will work ...
Username: Luke5513
Post Number: 30
so i would turn the gain down for the back speakers and up for the front? does the gain control the watts? thanks
Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp help [ « Previous ] [ Next » ]
