Thread: Need your opinion!!! |
Bronze Member Username: Caraudiofanatic
Post Number: 27 Registered: Nov-05
| Posted on Wednesday, January 25, 2006 - 11:14 pm: |
i was just curious on whether a hifonics brutus bx1205d mono amplifier for two audiobahn alum12n subwoofers. they are running 1000 watts rms a piece and are dvc 6ohm. i figured with it being a mono and all each sub would see the full 1200 but im not sure could you guys plz help me out on this one. thanks. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 5069 Registered: Jul-05
| Posted on Wednesday, January 25, 2006 - 11:19 pm: |
er - when u run 2 speakers/subs the overal wattage divides in 1/2 so if its 1000 then each sub will receive 500........ |
Post Number: 28 Registered: Nov-05
| Posted on Wednesday, January 25, 2006 - 11:33 pm: |
how can it divide in half if it is a mono and is 1 channel it should send the 1200 to each shouldnt it considering its a 1 channel |
Trinidad & T...
Post Number: 5073 Registered: Jul-05
| Posted on Wednesday, January 25, 2006 - 11:42 pm: |
wattage is not like house current whether or not u plug in 2/3/4 appliances it will get the same 110 volts in loose terms wattage gets diveded by the no of speakers/subs attached to that 1 source - if its 1000 & u hook up 3 it roughly = 333.333 if u hook up 4 then its 250 each will be getting . If ur a newb then i strongly suggests that u do some reading here www.bcae1.com ........ |
New member Username: 04yellowgto
Tuscaloosa,
Alabama
Post Number: 2 Registered: Jan-06
| Posted on Thursday, January 26, 2006 - 02:10 am: |
how are you planning on wiring the subs? |
Post Number: 4913 Registered: Dec-03
| Posted on Thursday, January 26, 2006 - 03:01 am: |
Hey Rovin, So this is where you hang out. |
Post Number: 29 Registered: Nov-05
| Posted on Thursday, January 26, 2006 - 07:46 am: |
i intend to wire them down to 1ohm hoping they would both see the full 1200 a piece. but i am not for sure should this amp be enough to push the power needed for those subwoofers. |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 413 Registered: Mar-04
| Posted on Thursday, January 26, 2006 - 09:42 am: |
the amp doesn't know how many speakers are connected to it, only the impedance. Whether you have 100 subs wired for a 1 ohm load (12w a piece) or 1 sub at 1 ohm (1200W), it will only do 1200w at 1 ohm. |
Post Number: 31 Registered: Nov-05
| Posted on Thursday, January 26, 2006 - 10:03 am: |
ok good so then the subs will see 1200 a piece. excellent. that is what you are saying right. |
Lawrence,
Ks
Post Number: 418 Registered: Mar-04
| Posted on Thursday, January 26, 2006 - 10:35 am: |
geez dude
Lawrence,
Ks
Post Number: 419 Registered: Mar-04
| Posted on Thursday, January 26, 2006 - 10:37 am: |
It's a 1200 watt amp. How is it magically going to make 2400??<br> <br> If you put 4 subs on it at 1 ohm is it suddently a 4800w amp?? If it is, we've just solved the world's energy problems!! |
Silver Member Username: Young_james
Post Number: 638 Registered: Sep-05
| Posted on Thursday, January 26, 2006 - 02:19 pm: |
^^^LOL Like optidriven said, the amp don't know how many subs you have connected to it. All the amp knows is the load that the subs combined make. If you wire your subs to a 1ohm load and plug it into your amp, then your amp will put out 1200. That 1200 is for the 1 ohm load, so how ever many subs you got connected to make that 1ohm load, then that 1200 is going to be distributed among them. If you have 2 subs, then it's 600 watts each. If you have 4 subs, they will see 300 watts each. It NEVER muliplies, but ALWAYS divides |
Post Number: 4956 Registered: Dec-03
| Posted on Thursday, January 26, 2006 - 05:23 pm: |
The all knowing sub  |
Silver Member Username: Blainew
Post Number: 748 Registered: Nov-05
| Posted on Thursday, January 26, 2006 - 05:48 pm: |
mathew amps put out the wattage that they are rated at.....doesnt matter how many subs...its 1200 TOTAL think about it...if amps played there rated amount of watts to EACH sub u hook up to it.....you could hook up 100 subs and get 100000 watts......notttt gonna happen |
Post Number: 640 Registered: Sep-05
| Posted on Thursday, January 26, 2006 - 06:53 pm: |
well said  |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 634 Registered: Jun-05
| Posted on Thursday, January 26, 2006 - 10:14 pm: |
mmm.... 100,000 watts. *drools* |
New member Username: Safe_cracker
Chicago,
IL
US
Post Number: 7 Registered: Jan-06
| Posted on Thursday, January 26, 2006 - 10:21 pm: |
Now if each voice coil had an impedence of 0 the wattage would carry over wouldn't it? How about 100 12" subs with dual 0 ohm voice coils, lol. They would never overheat....;) Polo.. |
