Thread: Which on to pick |
Bronze Member Username: Steven1234
Rahway,
NJ
Post Number: 91 Registered: Nov-05
| Posted on Wednesday, January 25, 2006 - 08:21 pm: |
im going with SQ i have 2 12inch diamond audio D6's in a ported box. should i go with a D6 1000.1,a memphis 16-mcd1000d or a crossfire VR1000d |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 5060 Registered: Jul-05
| Posted on Wednesday, January 25, 2006 - 08:33 pm: |
D6 subs r rated @ 600wrms - so why r u looking @ 1000wrms amps ?????... maybe a orion/kicker 1200 amp should be good .... |
Silver Member Username: B101
Queen City,
NC
Post Number: 714 Registered: Sep-05
| Posted on Wednesday, January 25, 2006 - 08:41 pm: |
rovin.. polident thread. |
Rahway,
NJ
Post Number: 92 Registered: Nov-05
| Posted on Wednesday, January 25, 2006 - 08:56 pm: |
how about the d5 1200.1 or how about some other ideas for amps that allow 1200 watts at one ohm. |
Trinidad & T...
Post Number: 5064 Registered: Jul-05
| Posted on Wednesday, January 25, 2006 - 09:09 pm: |
"d5 1200.1" - whats that , an older model ? the orion/kicker 1200 is 1ohm stable Also if u really want good SQ then use a sealed box instead.... |
Gold Member Username: Southern_bass
Paris,
Tennessee
U.S.
Post Number: 1111 Registered: Dec-05
| Posted on Wednesday, January 25, 2006 - 09:28 pm: |
www.cardomain.com , orion amps are half off |
Paris,
Tennessee
U.S.
Post Number: 1112 Registered: Dec-05
| Posted on Wednesday, January 25, 2006 - 09:31 pm: |
and yeah like rovin said for sq stick them in a sealed box |
Paris,
Tennessee
U.S.
Post Number: 1113 Registered: Dec-05
| Posted on Wednesday, January 25, 2006 - 09:32 pm: |
and even then if you dont like it you could keep the ported and go back to it |
Bronze Member Username: Do_em_dirty816
Kansas City,
MO
Post Number: 51 Registered: Jan-06
| Posted on Wednesday, January 25, 2006 - 09:33 pm: |
Yea what Rovin said if you're looking for sq go selaed rather than ported... Also the kicker kx 1200.1, the orion 1200d, and if youre on a budget the HIFONICS BX1205D might work (but you never know what you're gonna get out of hifonics). |
Kansas City,
MO
Post Number: 52 Registered: Jan-06
| Posted on Wednesday, January 25, 2006 - 09:34 pm: |
lol sorry 4 the repeat of the same thing we must of posted at the same time. |
