Thread: Orion SX wiring?? |
Gold Member Username: Invain
Michigan
United States
Post Number: 4108 Registered: Aug-04
| Posted on Wednesday, January 25, 2006 - 06:48 pm: |
I got an Orion 275 sx a while ago, and since it's like a 3rd gen amp, it's one with straight power and ground wires coming out, and a plug with wires soldered into it for the speaker wires. (You know what I'm talking about) Anyways, there's no markins to let you know which wires are for the left and right channels. There's a block of 4 wires, 2 on top and 2 on bottom, then a 5th one underneath, which I know is the remote power. I've tried looking in the online manual for the SX, but they don't show a diagram, they only give the color codings. Since the amp's not new, the last guy of course has different wires soldered on, so I can't use the color codings in the manual. Anybody know which channel is which? |
Michigan
United States
Post Number: 4109 Registered: Aug-04
| Posted on Wednesday, January 25, 2006 - 09:05 pm: |
Never mind, I found it. Had to take the bottom cover off, the colored wires were inside and went to the plug connector on the amp. |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 4665 Registered: Dec-04
| Posted on Wednesday, January 25, 2006 - 09:46 pm: |
I was going to say pull the plug off and look underneath it! lol |
