Thread: I have a RF p4004 and a RF T20001BD what electical upgrades do i need? |
| Posted on Wednesday, January 25, 2006 - 06:40 am: |
I have a RF p4004(60amp fuses) and a RF T20001BD(250amp fuse)what electical upgrades do i need,what size alternater do i need I already have a optima redtop battery? |
Gold Member Username: Carguy
Post Number: 5243 Registered: Nov-04
| Posted on Wednesday, January 25, 2006 - 09:38 am: |
You'll need at least 200A HO alternator along with "Big 3" upgrades under the hood. Redtop battery won't do any good with that kind of current draw. |
| Posted on Wednesday, January 25, 2006 - 11:47 am: |
What the "Big 3"? |
Post Number: 5246 Registered: Nov-04
| Posted on Wednesday, January 25, 2006 - 11:54 am: |
Alternator to battery, neg to ground, engine to chassis. |
| Posted on Wednesday, January 25, 2006 - 12:52 pm: |
Is that all the ways for grounding? |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 403 Registered: Mar-04
| Posted on Wednesday, January 25, 2006 - 02:02 pm: |
those are the three major current carrying grounds. There is a ground - somewhere - for every electrical circuit in your car. Some probably share grounds, but in my car, for example there are 20+ identifiable grounding points - most of which are very low current circuits using 16-18ga wire. |
Silver Member Username: Cadillacdb
Houston ,
TX
Post Number: 397 Registered: Aug-05
| Posted on Wednesday, January 25, 2006 - 04:48 pm: |
http://forum.ecoustics.com/bbs/messages/4/159194.html http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=5;t=007801;p=
Houston ,
TX
Post Number: 398 Registered: Aug-05
| Posted on Wednesday, January 25, 2006 - 04:49 pm: |
Copy an paste that last one but, those are links to all you should need to know about the Big 3 |
| Posted on Wednesday, January 25, 2006 - 07:44 pm: |
Is this the correct Big 3? 1)upgrade wire from alternater to battery? 2)upgrade wire from motor to frame? 3)upgrade wire from negative batt. terminal to grounding point? IS THIS CORRECT? |
| Posted on Friday, January 27, 2006 - 03:33 pm: |
Is this Correct^^^^^^^ |
