Thread: Running 2 amps?? |
Bronze Member Username: Goatin
Post Number: 11 Registered: Jan-06
| Posted on Tuesday, January 24, 2006 - 08:09 pm: |
how do you go about hooking up 2 amps do you need a capacitor? |
Gold Member Username: Tjmutlow
Post Number: 1223 Registered: Sep-05
| Posted on Tuesday, January 24, 2006 - 08:24 pm: |
most likely and you usually use a distribution block, and some amps have a line out pass through if running 2 sub amps, or use the 3 rcas on back of radio if it has them. |
Post Number: 13 Registered: Jan-06
| Posted on Tuesday, January 24, 2006 - 08:34 pm: |
So if I get an amp with a pass through how would I rate the size wire needed? Do you just add total watts and go for a wiring package that fits? And are you supposed to set the wire fuse to the same as the total fuse ratings of the amps? |
Silver Member Username: Cadillacdb
Houston ,
TX
Post Number: 388 Registered: Aug-05
| Posted on Tuesday, January 24, 2006 - 11:34 pm: |
Bcae1.com check out number 16 i believe |
Houston ,
TX
Post Number: 389 Registered: Aug-05
| Posted on Tuesday, January 24, 2006 - 11:38 pm: |
For all your Cap Questions refer to article 46 |
