Thread: DB/OCT |
Bronze Member Username: Ilyawizard
Post Number: 30 Registered: Nov-05
| Posted on Tuesday, January 24, 2006 - 01:50 pm: |
In setting up a crossover (in Alpine) what does db/oct mean and how does it affect the sound? I'm new at this. Is there a good manual on setting up a xover? |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 680 Registered: Jun-05
| Posted on Tuesday, January 31, 2006 - 11:40 pm: |
how steep a slope is per octave. if it will decrease it like 6, 12, 18, or some even have 24 db per octave slopes. Most people aim for an 18dB slope, which should be more than sufficient. |
Bronze Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 52 Registered: Jan-06
| Posted on Thursday, February 02, 2006 - 12:35 am: |
Ya, my sx1250's have a variable between 6 and 48db slope on the LP and 3 to 24dbs on the HP. So you say shoot for around 18db? now what the hell is the Bandwidth setting in the bass boost adjustment? ;) Polo.. |
Post Number: 37 Registered: Nov-05
| Posted on Thursday, February 02, 2006 - 12:55 pm: |
Ok, i got that thing about decibels, but how much is an octave??? I'm guessing it measures in Hz? |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 10880 Registered: Dec-03
| Posted on Friday, February 03, 2006 - 12:35 pm: |
www.bcae1.com look at the sections on crossovers, EQs, and slope. it's all explained and diagramed.
Silver Member Username: Racer501
ND
Post Number: 291 Registered: Jun-05
| Posted on Wednesday, February 08, 2006 - 09:22 pm: |
Mr. Bill at caraudio.com explains it fairly well: "Crossover Points I am sure you have heard the term 20 to 20 in refering to audio. Sound is just pulses of air pressure our ears can pick up. Frequencies are measured in cycles per second (Hz) which is just the number of pulses which happen each second. If your speaker moves back and forth 80 times in a second it is playing an 80Hz tone. It is generally acepted that the range of human hearing is 20Hz to 20KHz. KHZ is KiloHertz or 1000Hz. If you know piano, the fundamental tone for middle C on a Piano is about 263 Hz. You will not find any speaker anywhere which can produce 20Hz all the way up to 20KHz (that will fit in your car or that you can afford). That is why you use some combination of tweeters and woofers to reproduce sound. A typical 2 way component set will have the tweets covering notes from 3KHz-20KHz and the midbass covering from 80Hz-3KHz. The sub covers 20Hz-80Hz. In the system I just described the crossover points would be 80Hz (where the sub gives way to the midbass) and 3KHz ( where the midbass gives way to the tweeters) Crossover Slopes In the above example I listed a midbass/tweeter crossover point of 3KHz. If I were to unplug my midbass speaker and play a 1.5 KHz tone I should not hear anything, right? Wrong. The hand off between two speakers is very gradual. If you take two speakers playing the exact same note at the exact same db, the result would be 3db higher than one speaker. Since the falloff of a speaker is gradual, the crossover point is the tone where both speakers are down 3db. There are a few common crossover slopes: 6db, 12db, 18db and 24db. These are know respectively as 1st order, 2nd order, 3rd order and 4th order. What does this mean? In my example from above, if the crossover slope was 3rd order (18db) it means that for every octave below the crossover frequency the sound fades off at 18db. So if we were to unplug our midbass and play a 1500Hz tone (one octave below 3KHz) it would be 18db below a 3KHz tone played into the tweeter. tweeter attenuation In most car audio environments the tweeters end up very close to your ears while the mids end up further away. Since the tweeters and mids are playing at the same level it would make the tweeters sound louder than the mids since they are closer. This is why many crossovers will have tweeter connections for 0db, -3db, -6db etc... This allows you to lower the power to your tweets so you can match them to the volume of your mids. This is known as tweeter attenuation. FYI since every 3db drop is half power if you have your tweets set to -6db and running off a 100watt RMS amplifier you are actually only sending 25watts to your tweeters. tweeter protection Like any speaker, if you stress them too much they will break. Some crossovers will have fuses installed between your amp and tweeters that will blow at a predetermined wattage to prevent you from blowing a tweeter. impedence compensation [zobel network] This one is a bit harder to explain without getting into crossover design theory. Basically in order to design a crossover you need to know what the impedance of the speaker is. The components for a 3Khz, 6db slope crossover are totally different if you are using a 4ohm speaker rather than an 8ohm speaker. The problem comes into play near the resonant frequency of the speaker. As a speaker aproaches it's resonant frequency it tend to resist electricity more. For example, in a common 6ohm tweeter with a resonant frequency of 1Khz, the amplifier may see a 12 ohm load at 1Khz rather than a 6ohm load. This REALLY messes with crossovers because they suddenly see a 12ohm load and their crossoover point changes for that moment!!! A zobel network is normally used when you are driving tweeters down to a point near their resonant frequency. It is a set of components which divert power through a resistor near a particualr frequency (normally tuned to the resonant frequency of the tweeter) so as to show the crossover and amplifier a more consistant resistance. good stuff as always squeak. and thank you mr bill, that all seems on the mark. i thank Mikechec9 for all that info he helped me understand it all thanks again man |
