Thread: JL 1000/1 Turns on and off... help plz |
Silver Member Username: Drpthemc
Atlanta,
GA
Post Number: 120 Registered: Apr-05
| Posted on Tuesday, January 24, 2006 - 12:17 pm: |
Heres the problem... my 1000/1 plays fine for about 10 minutes of hard hitting bass, but after i turn the volume down and try to turn it up again the amp cuts off for some reason. i cant figure out why it does this. i went to check the amp, and everything was on and working... but no bass. i figured something was loose or something wasnt wired properly. i rechecked everything and i think everything was correct. it still had the same problem when i turn up the volume. well after playing around with it for a while i tap/shook the amp and the bass came back on...(i have to repeat this everytime it cuts off) ... why does it do this? i know its not good to do that to the amp but thats the only way it'll play... ahhh why does this amp cut on and off like that...danget Possible problems: 1. Is it because of voltage drop it cuts on and off? 2. new alternator?...(currently have a optima yellowtop installe) 3. the BIG 3 upgrade? (not yet completed) 4. Ground Wire? 5. Power Wire? 6. Finally is the JL AMP faulty?...(no warranty grrrrrr. -.-) |
Gold Member Username: Tjmutlow
Post Number: 1212 Registered: Sep-05
| Posted on Tuesday, January 24, 2006 - 12:19 pm: |
if you chan shake or tap the amp and it does that, then something internal with the amp. |
Atlanta,
GA
Post Number: 121 Registered: Apr-05
| Posted on Tuesday, January 24, 2006 - 05:11 pm: |
i was hoping that wasnt the problem... hmm dang |
Gold Member Username: Carguy
Post Number: 5239 Registered: Nov-04
| Posted on Tuesday, January 24, 2006 - 07:47 pm: |
When the amp shuts down, check the voltage going to the amp. If it's below 11v, then you have power problem. If it's 12.5v - 14.4v, and the amp still shuts down, it could be that the gain/level isn't set properly. Does the amp overheat? Also check and see if the amp's chassis is getting shorted to the car's chassis. |
Atlanta,
GA
Post Number: 122 Registered: Apr-05
| Posted on Tuesday, January 24, 2006 - 11:31 pm: |
i shall check that isaac... it doesnt overheat at all... gets a little warm but not to overheat... wut do u mean by "amp's chassis is getting shorted to the car's chassis"? how do i check that... -thanks guys |
Silver Member Username: Spyder
Eglin AFB,
Florida
Post Number: 267 Registered: Jun-05
| Posted on Wednesday, January 25, 2006 - 01:34 am: |
make sure that amp is not attached to anything metal including screws......have it mounted on a 3/4 thick peice of MDF with carpet over it if you can....also make sure it's not mounted upside down.....also make sure it's has a good ground......and last but not least make sure you have atleast 4 gage from your battery to the frame of your car instead of that cheesey 10 gage wire most cars come with under the hood! |
