Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp and speakers
Author Thread: Amp and speakers
Username: 04shaker
Hi new to this forum and have a question. I have an 04 Mach1 and am looking at putting an Audiobahn A8002T amp with 2 Alpine SWR 1042D subs. Does this sound like a good combinaiton? Or any suggestions.
Username: Tjmutlow
Post Number: 1173
no get a better amp, a 1 ohm mono amp those are dual 4 ohm subs. Like a kicker 1200.1 or memphis 1000, jbl, 1200.1 orio, there are many better then that amp.
Username: 04shaker
Cool. Looks like i will do the kicker 1200.1 at 1 ohm.Is there anything i might need? thanks for your help
Username: N2audio
Lawrence, Ks
Post Number: 404
Nice amp - under-rated. Ya might want to be extra careful with the gain.
Are you using your stock HU? Does the amp have speaker level inputs?
Username: 04shaker
ok. yes iam using the stock hu.I dont think it has speaker level inputs.Think this might be to much amp or not enough speaker?
Username: James1115
Wilton, Ct
Post Number: 4653
I would look into a aftermarket cd player if you ever want ot get full potential out of that combo. If not I recomend the JL audio clean sweep or you could go the cheap route and get a LOC for like $25 but have a very high chance of alt whine and engine noise. The JL clean sweep is $399 so it is for people who in no way at all want to sacrifice the stock look of there car.
Username: N2audio
Lawrence, Ks
Post Number: 408
excellent LOC's
http://www.davidnavone.com/adaptor_products.htm
Provide as good or better pre-amp signal from your stock HU than most aftermarket head units.
Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > Amp and speakers [ « Previous ] [ Next » ]
