Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > What brand for a 4 channel amp?? (ver...
Author Thread: What brand for a 4 channel amp?? (very good SQ)
Username: Blainew
Post Number: 694
i want an amp that will do somewhere around 100 RMS times 4 @ 4 ohms
what brand should i get..i want superb sound quality
Username: Tjmutlow
Post Number: 1169
how much do you want to spend, if cheap youll, needan amp that supposedly rated at200x4 maxpower, that would be @2 ohms, but you can try the infinity 7541, it says 111w
Username: Blainew
Post Number: 695
ill spend alot...
Username: Cenus
Hicksville, Ohio
Usa
Post Number: 1095
mabey a kicker kx600.4 it says 75x4@4ohm but most kicker amps are underrated so it probally do around 90watts.
Username: Southernrebel
Monroe, Louisiana
Post Number: 1882
"i want superb sound quality"
"ill spend alot..."
here are a few good ones...
RF T4004 $500+
JL 350/4
or go the "cheap" route and get and orion 4004. ~$150 :-)
Username: Pelona
Post Number: 127
how about this. LOL http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3403
Username: Rovin
Trinidad & T...
Post Number: 5004
to power what ???
i have a alpine F545 & it plays clean imo
that Jl 350/4 is very good
but since """ill spend alot...""" this http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=180&CF ID=704959&CFTOKEN=4c2e281ed1cbf37e-F9BB78B6-8A11-AAA6-88E1B5F06F7C809C
Username: Rovin
Trinidad & T...
Post Number: 5005
that Brax amp , omg ! - u can get 2 13w7 & 2 1000/1 amps 4 the price of that -lol...........
Username: Pelona
Post Number: 129
well he did say "ill spend alot"
Username: Tjmutlow
Post Number: 1182
JL 450/4
Username: Blainew
Post Number: 697
hahahaha i didnt mean thatttt much pelon
Username: Blainew
Post Number: 698
what about premier/pioneer amps?
their head units are the best....wouldnt their amps put out great sound too?
Username: Tjmutlow
Post Number: 1200
they are not know for their amps, stay with the kicker, orion Alpine, JL , maybe fosgate, and the Infinity. or even a Memphis.
Los Angeles, CA
Post Number: 2004
i used to have the fosgate punch 800.4 and it sounded pretty good. but it was the older model. i don't know how the new ones sound.
Username: B101
Queen City, NC
Post Number: 667
my pr200.2 sounds real good to me! I can turn my hu all the way up with out any distortion. it dont even hurt your ears, but get outside of the car, and its piercing loud!
but its only a 2 channel amp.
I dont have components either.
But Memphis has great SQ i think.
Username: Fandim
Reno, Nevada
United State...
Post Number: 615
a Phoenix Gold Xenon 200.4 gives you a lot of options, as far as impedances, etc, go. And are CEA 2006 rated, and put out more than their rated power.
Username: N2audio
Lawrence, Ks
Post Number: 370
Pioneer Premier amps are ridiculously under-rated on RMS power. They routinely bench test at close to twice their published power. Excellent amps IMO, just not that common.
Username: Pelona
Post Number: 155
well then how about this blaine http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=588
Username: Spyder
Eglin AFB, Florida
Post Number: 266
I would Recommend the Jl or the Zapco First.
and orion and kicker second.....all are good amps but the zapco amps are hard to beat. take a look on ebay for that zapco amp....i seen one the other day.....also a buddy of mine has a couple zapco reference amps on ebay.....i think he might have a 4 channel on there that will be more then enough for ya! will post a link in a bit when i find it!
Username: Insearchofbass
Post Number: 4361
seth did you buy the xenon ....think that was you
Username: Spyder
Eglin AFB, Florida
Post Number: 270
well i was wrong all he has listed is the 200.2 and the 350.2 listed......sorry for the misconseption on that!
Username: James1115
Wilton, Ct
Post Number: 4644
PPI pcx 4100 is a fantastic amp:-)
Username: B101
Queen City, NC
Post Number: 686
PPI SQ is outstanding!
Username: Safe_cracker
Chicago, IL
US
Post Number: 13
Old school A\D\S http://cgi.ebay.com/ebaymotors/ADS-AMPLIFIER-6-CHANNEL-AMP_W0QQcmdZViewItemQQcat egoryZ38638QQitemZ8032525291QQrdZ1QQsspagenameZWDVW
JMHO...Polo.
Username: James1115
Wilton, Ct
Post Number: 4705
that is a very nice amp Polo:-)
Username: Pelona
Post Number: 217
Why is that amp 6 channel?
ive never seen a six channel amp without channels for subs.
Username: Fandim
Reno, Nevada
United State...
Post Number: 639
Sean, I have a xenon 1200.1, and two 600.1's, not using them for my 4-channels, though.
Username: James1115
Wilton, Ct
Post Number: 4706
Pelon that amp is made before they had dedicated class d sub amps. You can run 4 speakers and bridge the last 2 chan to your subs or run 6 speakers, or 3 subs. That is USA made a/d/s very high quality stuff:-)
i am in the same boat. I am looking for a 4 channel amp to push 2 sets boston 4" componets and 2 jl audio 12w3 in a band pass box, any help guys. a buddy of mine told me to look in to autotek amps are they any good?
Home > Message Board > Car Audio > Amplifiers > Archive through January 28, 2006 > What brand for a 4 channel amp?? (ver... [ « Previous ] [ Next » ]
