Thread: Mixing diffrent sub models together |
| Posted on Monday, January 23, 2006 - 12:49 am: |
i have a 12 stroker dual 2 ohm which is 4000 watts,and a 2400 watt 15" stroker dual 2 ohm which is a older model. can i mix these two together and form a 2 ohm load ok without any probs? |
Silver Member Username: Pelona
Post Number: 123 Registered: Dec-05
| Posted on Monday, January 23, 2006 - 01:36 am: |
dont do it. different size subs will play the same frequency differently. so it will sound like sh!t. And the 15" will probably overpower the 12 so you wont be able to hear it. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 5009 Registered: Jul-05
| Posted on Monday, January 23, 2006 - 08:01 pm: |
AGREED ^^^ |
Silver Member Username: Fandim
Reno,
Nevada
United State...
Post Number: 616 Registered: Jun-05
| Posted on Tuesday, January 24, 2006 - 08:42 am: |
Heh... should never ever ever mix different subs on the same channel.. But yes, you could end up with hte 2 ohm load you wanted.. each would get equal power, but it wouldnt sound well at all. |
| Posted on Wednesday, January 25, 2006 - 01:01 am: |
i noticed on my 12" stroker,the box is tuned to 36hz and subsonic filter is on 20 hz, on the low bass notes, it's like their filtered out. but on high bass notes their not, any suggestions? |
